h8ps cam positioner and Simatic S7-300
sylwek
Feb 2004
Poland
26
Hello,
I have Omron Cam Positioner H8PS-16BP
, and I want connect this device to PLC Simatic S7-300.
Does the cam Positioner H8PS-16BP is compatible with plc s7-300?
In Simatic PLC there are standard 24V DI and 24V DO.
Can I connect Omron cam otputs (PNP open collector) to digital inputs in Simatic S7-300 SM321(24V) module?
Can I connect 24V digital outputs (in S7-300 SM322 module)to Digital inputs in Omron H8PS module ???
Hello all, I'm looking for ideas or solutions on having a industrial webcam or IP camera that we could use on our equipment to help monitor and...
1,219
Kindly, I was trying to use the Motion Arm Output Cam (MAOC) instruction on a Rockwell plc, but I need to have it in a general AOI function. So, I...
1,035
If a polynomial is used in a cam-profile for motion control, you normally have the option to displace the inflection point from the standard 0.5...
1,445
I have submitted this tread to a magazine and it got rejected by the editor that obviously has never done motion or used cam tables.
2,121
Hello to everyone. There is an inductive sensor to control the angle on the "Balluff bsw 819" rotary cam switch in a 1000 ton mechanical press...
1,123
