hardware configuration of s5-95u
mehkocak
Jan 2005
58
if you have any experience with s5 plcs can you tell me how can you do the hardware configuration of s5-95u.
thanks
The S5-95U has a fixed configuration.
The onboard i/o has the addresses I32.0-I33.7 (digital inputs) + Q32.0-Q33.7 (digital outputs) + I34.0-I34.3 (digital inputs with interrupt) + IW36-IW38 (counter inputs) + IW40-IW54 (analog inputs) + QW40 (analog output).
Additional i/o that is added in the same way as for S5-100U series starts with I0.0 or Q0.0 in slot 0.
The various counters, analog i/o and interrupt inputs are enabled in DB1.
What do you want to do?
hi mehcocak,
I suppose you need to configure the analog inputs or counters. You need to access DB1. If you tell what do you want to do, i will try to give the solution or send you the handbook.
good luck
yes that's it
I should configure the analog inputs and also if I add more digital inputs and output what about the adresses.
thanks
analog inputs
Hello
If you need to use the integrated analog inputs, you must write the number of inputs you need in the DB1, parameter AI. For the addresses, use the information of jesper. There are a lot of parameters in DB1, I have a handbook (8.195 kb) where everything is explained.
To know about more addresses of external cards you should have the handbook. ¿how can i send it to you?
Hi all, This is going to be a long post apologies. I'm also a complete beginner to the world of PLCs. I'm currently working on my first ever...
478
Hello Folks, I am beginner to the PLC programming. I am working on a project which has Siemens S7-1516-3 PN/DP CPU, and ET200SP profibus based...
337
Hi everyone, I'm trying to learn how to make hardware configuration. I have an IM on profibus. I added the whole group (I dragged the marked taxed...
1,175
When I download a hardware configuration using the step 7, it first asks me to select the target module. Only option that is offered is the CPU...
1,211
Hello, Here i have a Tia Portal V11 Project that i wanted to fix but i cant take the device configurations from the device. So i just have to...
1,480
