Hardware for Remote Access
Apr 2002
Just a bit northeast of nowhere
1,117
Hello All,
As the years fly by, our facility is increasingly trying to buy new equipment from OEMs, rather than making our own. This complicates things, because it's all proprietary, and these guys would rather give me their liver than their PLC password.
That said, these OEMs have decent support, but they need to remote into the machine to access it for troubleshooting. To do so, they make many requests of our IT department, like a dedicated IP address and access to our LAN. Naturally, IT keeps such things locked up tighter than Her Majesty's chastity belt.
We are now looking into a wirelss hotspot (with a physical LAN port), or some other solution we can use to provide direct, temporary remote access.
Does anyone have a suggestion?
Thanks,
TM
There are many VPN providers that are tailored to industrial applications.
We use E.W.O.N. This is a router which sits between the machine network (LAN side) and the customers network (WAN side). The customers network must provide an internet connection to the router. They get access to setup the router any way they want on the WAN side.
This is super easy for the customer, but they have to trust that the LAN/WAN VPN connection is safe.
Another similar vendor is MB.net.
Another solution is that the customersIT department setup a VPN connection (or several VPN connections) for outside subsuppliers to get access to the machines they have delivered.
IT department may like that better because they can then keep full control. On the other hand, the machine suppliers then have the problem of having to juggle many different VPN connections, so they dont like that so much. An advantage for the machine supplier is that the costs are usually on the customer.
E.W.O.N (and others) also have versions that do exactly that.
edit: browse down to the bottom of this page: https://****.biz/products/cosy
There you can find the part no for a router that supports 3G or 4G.
edit: You have go to replace the "****" with "e w o n" (without the spaces) in the above link. PLCTALK has an issue with E.W.O.N. Dont know why.
+1 for the Stridelinx. Even though the boss makes me play IT guy sometimes, I'm not even an amateur with advanced networking. The Stridelinx is extremely easy to set up.
I have 6 customers that I support using the Stridelinx. I can access their HMI from my phone or PC after logging into the web portal. If I need to access the PLC(s) or upload/download the HMI program, I can click VPN, and after a few seconds, use RSLogix or Crimson painlessly.
The Cosy has one advantage that I have heard about: It can be configured without use of the internet. It can be more complex to configure. I have one of them that I managed to lock myself out of once. That made for a 6 hour round trip to get back going.
I have made numerous changes to the configurations of the Stridelinx using their web portal and I haven't jacked one up yet.
Dear All I realy need help with this one :) TIA Portal v16 CPU 1517F-3 PN/DP In my Profinet network I have: 6 of ET200 IO modules 1 of 1214FC...
1,158
I wont to use a SLC 5/03 and have one remote rack. What cards do I need for this ? Does it matter what slot I put them in ? If they go in the...
39
9,373
Hi Has anyone come across or used some simple remote control hardware. I only need 4 digital push buttons to be sent to the PLCs digital inputs...
2,556
I have an 1769-L16ER that I use to test code and I just found that I can't create MSG tags at the local program scope - they have to be done at...
194
Hi all, This is going to be a long post apologies. I'm also a complete beginner to the world of PLCs. I'm currently working on my first ever...
454
