Steve Etter
First, thanks to all for your comments. This is all really good information and I always like learning how to think a little differently about a problem than I already do.
Archie - Looking at your scheme (Momentary Pushbutton Control Full Circuit), I agree that it will work perfectly for PLC control but could potentially have one problem in the hardwired world if not taken into account...your pushbutton must have the N.C. contacts "making" before "breaking" the N.O. contacts. If you don't, the latching circuits will drop out as you let off the pushbutton.
pkshaver - I thought about using a programmable relay, but in the industry I am in (as an OEM), the lower tech I can go, the better. I would prefer to stick with old technology if possible..even if it is slightly more expensive..to keep from having to store and/or keep track of additional programming.
Gerry - I still haven't looked at the ratchet relay yet, but I believe it will be one of the two solutions I will end up using. Thank you.
Eric - First, yes, I do need to toggle with each press..but your point is well made. Second, thanks for pointing out the maintained foot switch option. I have never had to find and order a foot switch before, so I was not aware of this option. This is my favorite solution and, provided I can get one from my supplier, it will be how I go. Thanks.
Steve
Steve
