HC900 I/O list Import
Sep 2006
Chicago
I am working on my first project using a Honeywell HC900 Hybrid controller. It is a medium sized project (several hundred I/O only). (yep, a "NEWB" again :nodi:)
Does anyone know whether or not there is a utility that could import, say, a CSV file from Excel? I know that I could do it with AB PLCs so I was just wondering if there was a way to do this with the HC900.
Thanks in advance.
Dave, I presume you've discovered by now that the answer is 'no', there is no import function in the HC-900.
The Control Station HMI panel will import the tag data base from the HC-900, but there's no import for the HC-900
Dan (yes, the same one)
Thanks Dan!
Thanks Dan!
Yeah, I kinda knew the answer before I asked the question:)
But, ya never know, it coulda been good. :ROFLMAO:
I miss being able to edit large I/O blocks and stuff offline with Excel, like you can with the AB stuff.
It's not worth the time to slice and dice the DB structure of the HC900 to figure it out either.
Cheers,
P.S. Tom at TAC was very helpful. I need to work out the SP Program block usage. I will talk to Bob S. Monday (he is on vacation)
I'm upgrading an existing machine with a Honeywell HC900 controller, and I'm trying to do some data processing in the controller. I have variables...
70
Hello everyone, My designer software as the 7.200 firmware, but when I go to download to the plc HC900 from honeywell the program I created...
670
Hello everyone, In the designer softwar of the plc HC900, I used the function version control on the toolbar and it deleted files from my...
361
Hey Guys, I am getting random rack/slot errors. I go to download and everything is ok but then it has a error. For example - Yesterday everything...
373
Hello Guys, I'm working on Honeywell HC900. I am using the PID block. I have attached the Switch and loop block to it as well. I have attached a...
642
