Goodknight436
Hi Guys
Thanks in Advance!
GOAL: I have HC900 PLC and a CS15 HMI that I need to configure alarms for. The goal is to require the user to acknowledge the alarm before proceeding with their procedure. To do this I decided to use the HC900 alarm groups because they are essentially already set up in the HMI for you when you import the tags far as I can tell from the manual.
PROBLEM: The trouble I ran into was after I imported the tags to the HMI, the pre-configured HMI alarm groups page only display the first alarm on every group and no other alarm groups I set up in the HC900. Also the alarm group page does not show any of the signals that are in it other than the title. I already looked through the manual and online and cannot find anymore information about it
QUESTION: Is there some other steps I need to perform to get these alarm groups to work or is there another way I can require the user to give feedback before the process starts up again. I would play around with these things myself but I don't have a deadline and the HMI and PLC are over a week away in the mail.
Thanks in Advance!
