Hello again quick panel view ?
controlconcepts
Oct 2008
boston
300
I have a PV1000 Color Touch 2711-T10C10
and it has the DeviceNet option card.
I have found a DH+ comm card for the same type of PV.
My question is can they be swapped out?
Or is there more to it than just changing the card?
Will the PB32 Recognize it upon a upload?
Thanks again,
Matt
There's more to it than swapping out the hardware. PanelView Standard terminals are not meant to be modular.
Each PanelView variation has a specific firmware file, and the field firmware upgrade utility only allows you to load the firmware for the existing variation into the terminal; you can't load a "PanelView 1000 Color DH Plus" firmware file into a terminal that already has "PanelView 1000 Color DeviceNet" firmware.
I'm sure it could be done at the factory, but none of the tools available to the field (including to RA's own service engineers) will do so.
Thank you Ken For your FAST,accurate, and overwhelming knowledge on this stuff. As on of my vocational teachers used to say " I am an inexhaustible fountain of knowledge, what do you want to know " I see you as that fountain!!!!
Thanks again
Matt
have not had much experience with logix 5 and just trying to use the y=MX+b equation to do some scaling in my test rig. The rungs in question...
19
3,796
Could one of you plc gurus explain to me,or show me in ladder logic terms how to use the (strn) command i have direct soft5 software and a 205 plc...
1,495
I have an HMI 2711R - T4T Series B, and I want to know which PLCs, besides Micro 820, can communicate with it.
114
I want a free plc programming software that is available for download onto laptop or pen drive. I have read books at length, I want to do...
4,091
Hi guys. Im in need of some help. Im working on a down hole tool. one of the sensors failed and it is stuck down hole. I cannot find a way to...
2,229
