help citect scada io problem
THIRDFOOTS
Jun 2011
MELBOURNE
hi all
I am trying to do my first project with scada .I have a book that is explains some of the how to`s
but ..... i have hit a problem ....i have attached a screen shoots what is coming up.
can you see a problem with what i have done here ?
your help with this will be greatly appreciated
Address is incorrect.
What is your I/O device?
Is it and Omron PLC?
If so you may have to use DM instead of D.
hi bob
thanks for the reply
do you need a i/o device configured to compile the file?
i have not done that yet
no the plc will be a ab of some sort
but i will give dm a go
dose D need to be in upper case?
yes
you will have to configure your I/O device so that Citect knows which driver to use and the addressing for the PLC model
Check the Citect help file for the driver as to which memory areas of the PLC can be addressed and the correct addressing format to use
ok thanks for your help...
i did not fix the problem ....
but what i did was went back and started from the start.
what ever i did last time i did not do this time and the program worked.
i will spend some time on the other program and see if i can get it to work my challenge for the week...
134
Hello Everyone, I am working on reports in Vijeo Citect V7.40. I want to generate a report whenever I press the button. I am able to generate it...
894
Excuse my inexperience with cicode, I have a citect issue I need to make "Global" where the line below is shown in bold in the below function...
3,270
Hello Everyone, I am working on an already existing project updating new equipments installed. I have no prior experience in this field but I do...
3,486
Hi, I am maintaining a Citect SCADA with 2 x IO servers and 2 x File servers. the version of Citect is 5.21.00 Service Pack G. I have my project...
1,946
