Help communicating to 1794-ASB/E Flex IO with a Control Logix 5561
ChuroChurp
Jan 2009
Toronto
Hey guys,
I am trying to get my DHRIO scanner on my control logix to communicate with my 1794-ASB Flex IO scanner. On RSLogix5000, I had set up the DHRIO scanner module in its proper slot. I can download this configuration. However, when I add the adapter (1794-ASB) there is a problem downloading. I have the dip switches set all on so the starting group is 0 and the rack number is 0. I am only using 1 input module and 2 outputs on my RIO. I have the scanner cable selected to scanner B. I also added these modules to RSLogix5000, but i still get an error. The PLC shows that channel B is communicating OK, but the CH B LED flashes red. I have done everything the manual suggested, I am using standard addressing and all adapters and remote IOs have been addressed correctly according to the manual. The error I get is says invalid link address. Does anyone know what the error might be? I have tried everything.
Just had a thought:
If I am using standard addressing, in RSLogix5000 do I list the slot number as 0,1, and 2 respectively for my input and 2 output modules or do I list it as group 0,1, and 2 respectively and have the slot number as 0?
Please clarify the settings on your DHRIO module. There are 6 rotary dials (3 for each channel).
Hey guys,
If Channel B is flashing red, that means one or more nodes are not responding in the I/O tree.
-cable not wired properly, try switch the Blue and Clear
-no termininating resistor on both ends
-Baud rate is wrong
-1794-ASB not configured properly
A few weeks ago while walking through the back part of our plant an coworker and I found an old GE Versamax Micro PLC (IC200UDR005-BB) on the...
2,506
Hi everybody, I'm new to Rockwell/Allen Bradley and need some help here. The client has 4 SLC5/04 CPUs in the plant, all in a DH+ bus and...
1,719
Please help me in configuring my PLC and Internet setting. I have uploaded system architecture, please check out. Thank guys.,.,:(
1,180
help in communicating GX Developer(Fx1N) with Citect scada 7.20--- serial communication.
4,237
hi everyone, my problem is that whenever i try to view accessible nodes or try to download the object files into my plc, it generates differnt...
2,536
