HELP! Downloading to 319F
wrgant
Feb 2018
South Carolina
I have a new PLC I am trying to commission. It is a Siemens 319F. I downloaded the hardware configuration but now when I try to download the safety program or hardware configuration it asking me for a password. I tried to enter to safety program password but this did not work... any ideas? Attempted to attach picture
There are two passwords. A software password for the safety program, and a HW password to prevent unauthorized access to the PLC.
I dont recall setting one up... I went to PLC -> Access right -> Cancel and it said there was no password set. Any thing else I could check?
Something doesn’t match. You have a prommer to delete the memory card?
Or a Siemens pg ?
Edit
Or a spare mmc for a test?
Yes. With those mmc”s
You need the prommer. If you try to delete using Step7 and mmc in cpu... it still asks for password
Try it
So you have a spare mmc to try a new download?
I don’t have any other ideas. Maybe someone else will chime in.
Basically you need the correct password
I could help if you were in SC :)
I am sure that I seem very stupid at this point for asking such an elementary question. I have for the most part only worked with AB products. I...
2,206
At my work place, I programmed a totalizer for one of the plants with OB35 which worked fine. I later took the same to another plant, it did not...
2,997
Gents I have an FX-48MR Plc and am using Melsec Medoc Version 2.20 I am downloading a good program that is working to the laptop but when I upload...
3,674
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
110
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
142
