Help - GX WORKS2, Structured Data Types and Timers
Isthmus
Mar 2018
PT
I have a project that i have to use a Mitsubishi FX3G with GX WORKS2, wich i never worked with before. I´ve been working with TIA Portal from Siemens.
I´ll be using Structured Project/Structured Ladder and perhaps a few functions in ST.
As title says, does a Structured Data Types equals to a "Structure" in Tia Portal? If i create a structured data type "SDT1", with, for ex:1 Bit/1 Word/1 Time, is it possible to move all the contents of SDT1 to a new SDT2? Or i have to move the devices? Like M1/D1/D2 > M2/D4/D5 ?
Why doesn´t GX Works2 give me no error when i put the same device/adress in a VAR in Global_Label and the same Device/adress in a VAR in a Strutured data type? Makes no sense i guess. Please see attached file(testings i´ve been doing).
Regarding TP/TON/TOFF timers, is it possible to reset them while they are counting? Or i have to use OUT_T timers? Or even timers with counters as they have a "reset" function.
Thank you.
Isthmus
Hi there, Can someone shed some light on the following instructions: OUT_C_32 DINT_TO_INT Thanks.
1,940
Hi, I am new to Mitsu, know RSLogix 500/5000, micros, etc, and am translating a dynamometer controller application from RSL5000 to GX Works2 on a...
6,053
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
93
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
461
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
173
