Help in PLC Programming
Kirsten
Nov 2006
Biñan
hi! I'm new in PLC programming, so can u help me to find and recommend a good book for a beginner like me, especially PLC programming using Omron products like Zen...Hoping for replies.tnx.
And one more thing,can u help me to write a ladder diagram using Zen with this. Given with one switch and 3 output Light bulb(lamp),whenever a switch is flicked it changes the light to other lamp sequentially.I mean if i flicked the switch,Lamp 1 will turn on,and i flicked it again,then lamp2 will turn on,but the lamp 1 will turn off...then so on...
Plz help me on this...thanks.
kirsten
Check out the "learn PLCs" link at the top of the page for a basic introduction to the instructions available to you. Then write out the logic in step-by step detail (i.e. if light A is on and button X is pressed, turn off A and turn on B).
Hello All, As you can guess by the title I am a total noob to programming PLC's. So my problem is that I have an old Pallet wrapper that uses an...
21
4,928
Hey all, I have this old code am trying to convert. Never worked with this PLC before. The 2 rungs are attached. What is happening here? What are...
5,117
Hello Guys, I'm new to PLC programming and a course I'm currently studying has asked a question and requested we use a shift register. The...
20
5,967
I am in need of some help to perform a simple task in RSlogix5. We are using RSview32 to control heat zones on an extruder barrel. We have...
1,539
Hi, I'm new to this Forum. Can anybody help me with following. I want to reprogram an old Matsushita (Panasonic) NAiS FP3 PLC. CPU model no...
3,135
