Help Me. Profibus Error??????
yyscom
Oct 2005
Chung-ju
Hi every one
I need help. Please
I S7 CPU 315-2DP is in operation in korea
Me so much, such as attachment problems.🔨
Who can help me!!!!
PLEASE.
Event 1 of 10: Event ID 16# 2942
I/O access error, reading
P area, double-word access, Access address: 0
Requested OB: I/O access error OB (OB122)
Priority class: 1
External error, Incoming event
Any help is appreciated,
1. PS 307 5A
2. CPU 315-2 DP
3.
4. CP 342-5
5. CP 341-RS232C
6. FM352 CAM
7. AI18x12Bit
8. DI16xDC24V
9. DI16xDC24V
10. DI16xDC24V
11. DI16xDC24V
Hi yyscom.
That is not what LD asked about.
If you are in doubt, then post a screenshot from STEP7 Hardware Configuration. Be sure to display the station where the i/o adresses I0.0..I3.7 or IW0..IW2 is used.
Another thing you can investigate, is what is the status of all LEDs on the CPU, CP modules, and IM modules. And check both main rack as well as subracks and DP slave stations.
Hello everyone , im using a IM153 as Decentral Peripherie, it uses profibus and it is a slave with the adress N° 2 everytime there is a problem...
646
After replacing the 70 with the 525, the PLC can read from the drive and recognizes it as online, but no commands are being listened to. PLC is...
584
Ok, We have a couple of hundred PF753's with 20-COMM-P cards installed. I recently had one fail, and it would not communicate over the...
2,144
Dose anyone have experience with Beckhoff FC3121 profibus master PCIe card connected to Siemens CP342-5 as a profibus slave? The data retrieved...
17
4,853
Hello dear members. I've been looking for a GSD file of a Litronic pulsregler with no success. I Cant even find a contact of the manufacturer. By...
1,303
