Help. MicroLogix via Ethernet to Power Flex40
Dec 2008
Toronto
42
Hi. I have a Micrologix 1100 setup talking to a PowerFlex 40 through Ethernet (22-COMM-E) setup using the PCCC object using the "N40 Files". I am having issues sometimes getting the Drive to initiate a start command consistently. I am able to send it all it parameters and get feedback just fine. Is there someone I am doing wrong. I read this article from Rockwell website. Maybe this has something to with it. Can some explain what this means to me?
“Powerflex 4 & 40 Control Signalling. Drive does not always start reliably
The default condition of the start and stop control inputs for the PowerFlex 4/40 drives is 'Edge Triggered'. This means that the drive logic must see the stop input high (or true) before the start transitions from a low to a high state. Therefore, if both start and stop inputs are applied simultaneously, a 'Race' condition can exist where the start input goes high before the stop input. In this condition, the drive does not respond to the start command and stays in a stopped condition until the start input is toggled. Test results have shown that the minimum time overlap that insures that the drive responds to the start input is 25msec. Therefore, in control systems that require both start and stop inputs to be applied during a drive start sequence, the start input should have a delay of at least 25msec after the stop input is applied.”
Hello, As my user name implies - I am totally new to the wonderful world of PLCs. I have though been tasked with integrating into our larger...
2,216
Hello everyone, I'm having an issue trying to get a messaging instruction to work. I'm trying to get some data from a Micrologix 1400 to a L83E...
18
6,220
Hi all Looking for some help please so I was connected to my MicroLogix 1000 threw rslinks had no issue. I download a program now this program...
46
13,088
I've attached pics, below. I'm in the field right now an am trying to communicate to the Micrologix 1500 through the 1761-NET-AIC (Ugh!) to...
1,954
Hello all. I need some help setting up a MSG instruction to transmit 10 bits of data from a compact Logix processor to a micrologix 1400. I have...
31
20,130
