Help Momentum 171 CCC 960 30
Engineer1
Jan 2005
In a decent flat
24
Hi All,
I am new in the game of PLC's... enjoying it thusfar.
I need to communicate with a 171 CCC 960 30 momentum CPU, as far as I know it already has an IP address assigned to it, but if I ping to that address it says "host unreachable". From the reading I have done, looks like i need ProWorx Nxt and bootplt.
I can get proworx... but where can I download bootplt.exe? Google has let me down!
The setup for the system is a simple 171 CCC 960 30 plc via a 3Com SuperStack II 40 hub onto a WinXP based machine/i also have the option of going Win2K. Oh... on Concept2.5
Help will be appreciated.
Engineer1
Hello i need help, I've two momentum plcs with the processor 171CCC98030-IEC and i need to put the 1º plc to read and write registers in the...
3,344
I am having problems figuring out how to associate modicon momentum analog inputs, and outputs to the tags I've defined in my PLC program (Concept...
6,339
Hello, doing switch from FBD to ST. First task is converting my old work. How do you sum variables? For example, Interlock1, interlocl2 and...
76
Hi guys, I need help with position control using a Veichi AC Servo Drive model SD600A1-T2-2R2. How do I know how many pulses for it to rotary 1...
34
Hi friends, i need a help to know the procedure and steps to connect Lenze i700 to PC for parameterize. i tried with lenze easy-starter using LAN...
40
