Help! Need Modicon B572-010 A.O. wiring info
plcguy111
Aug 2013
Louisiana
A friend of mine and I are pulling out on old (failed) 484 system as a charity project for a propulsion system on a ship that is used for disaster relief. Replacing with A-B. We demo'd the I/O and later realized we did not have a single drawing showing the wiring polarity between the old B572 Analog output module and the Avtek regulator model (used for generator excitation) analog input. Cannot find a manual on the regulator modulator either. If I could find a manual for the analog input module showing the field wiring connections, the problem would be solved! Thank you in advance for any help you can give!
Can anyone help me with serial communication between a modicon plc E984-265 and an AB powerflex 4 drive. i have looked through the posts and...
5,507
Hi everyone I need to evaluate a Modicon Concept application. I got an ASCII file of the software can anyone import it, print and email it back to...
1,272
Hi everyone, I'm programming a quantum 434 using Proworx Nxt. I need to set an internal bit whenever a value stored in a register does not equal...
2,143
Hi all! Got some problem here. Does anyone know the hardware/software required to upload/download program from a; AEG Modicon A020 E 220V EN...
11,426
HELLO ALL, I AM WORKING ON PROJECT FOR ONE OUR CLIENT THE PROJECT IS IN Modicon Concept v2.5 using Ladder Logic PLC : 140CPU11302 Concept is new...
2,778
