Help!!! Need to write a pause cicode function
Zenn
Aug 2004
I have a auto-start button with the function with the coding of the following:
FUNCTION
StartAuto()
INT Counter = 0;
WHILE Counter < NumCycles DO
MoveCyl();
ResetAGV();
Toggle(Conveyor);
SleepMS(1000);
Toggle(HW_Valve);
FillMixTank();
Toggle(HW_Valve);
Storage_Tank = 0;
Toggle(Mixer);
MoveAGVTank();
Toggle(Conveyor);
Toggle(Mix_Valve);
FillAGVTank();
Toggle(Mix_Valve);
Mixer = 0;
MoveAGVTank();
Toggle(Extract_Pump);
DrainAGVTank();
Counter = Counter + 1;
END
END
How do i construct a function to pause the above function??
what do you mean with pause ??
you already used the sleepMs function thats a pause and you have the sleep function to pause for seconds.
you can write a controlling function to start and kill the task when you want.
function controlfn()
int hTsk=-1
while true do
if dotask and (htsk = -1) then
hTsk = tasknew("startauto", "", 8)
end
if not dotask and (hTsk <> -1 then
taskkill(hTsk)
hTsk = -1
end
sleep(1);
end
end
hope this helps
Greetz
That's not what i wanted, The pause button should temporily stop the StartAuto() until it was pressed again before the StartAuto() resume.
Sorry. I may sound a bit stressed. Cause i need to hand it as a assignment by tomorrow..
it is just a variable that says if the task should run or not. it can be anything. a tag, a function, ...
greetz
look at the tasksuspend and taskresume functions they do exacly what you want.
start the task with tasknew to get the handle or use TaskHnd to retrieve the handle of the task.
greetz
I new to this....
But i try...
But what is a handle to a task?
hello guys,
i need a timer or counter .of course i made it but didn't work that is:
FUNCTION
counter()
[FONT=Courier New (Arabic)][FONT=Courier New (Arabic)]
[/FONT]
[/FONT]IF V21 = v22 THEN
[FONT=Courier New (Arabic)][FONT=Courier New (Arabic)][/FONT][/FONT]V23 = v23+ 1;
END
END
anybody can help me?
Hi every body. I am new here also very new in PLC coding. I need to write ladder code for the following conditions. 1. When you press the button...
46
10,093
I need help writing a plc lab ladder diagram for class. Can anyone help? Please!!!!!!!! Its a clamp and grind.
34
6,516
Hi, every body! I have a small project. I wrote programmer control two pump motors by plc s7-300. Now I want to write programmer connect PLC to PC...
5,416
50
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
347
