Help On Hsc:0.hip
senen
May 2004
46
HI,
Presently we have an application program with HSC:0.HIP set
to 900.What we like to do now is add a selector switch so that
we can change HSC:0.HIP value to 1200.In this way by means of
selector switch we can can select HIP value to 900 or 1200.Is it
possible to use MOVE instruction to do the job???If not ,what is
the best solution???
THANKS,
Senen S.Casio
I assume this is a Micrologix. Using the inputs from selector switch do a MOV into HSC:0.HIP
Any of the function files can be used just like a register.
HI,
Thanks so much for the help....as long as i enter this rung,,,
in the function file i can just leave the hsc:eek:/sp bit to zero.???
Thanks again,
Senen
Also remember there is a pot that can be used to adjust this value. Set it so the min value will be 900 and the max 1200 and then you can have any value in between by adjusting the pot. May not be applicable in your case but handy to know. Alan
Hi everyone, I have a Micrologix 1400 using an HSL instruction (High Speed Counter Load). This instruction is used in junction with an encoder...
829
Is it possible to write to the high speed counter function file "high speed preset" on an AB micro 1100. I have the HSC set up with a MOV...
1,104
Hello all. I am having trouble setting up my HSC to count pulses from a prox switch. I have it wired to the prox and I see the .InputStateA0...
1,383
So I have to encoders with A,B and Z pulse 360 encoder wired up to A0+, B0+ and Z0+ and the - pulses wired to common 24vdc. I can see the inputs...
1,044
Hello All, This is my first time working with encoders and I am a little lost. I have a 1769-HSC/B card on a Compactlogix L32E controller running...
3,015
