Help !!! online with Micromaster
Mar 2017
6 October
69
Hi all ,
I have 3 micromaster installed in machine connected to CPU throw DP
I want to go online with them to upload parameters ( i do not have the original program of the CPU )
I have Laptop , Starter software , PC adapter USB A2
I can find the drives in Accessible nodes but i can't connect to them ( Accept not available )
Can anyone help me ?
If you do an update twice and still get the question marks...
Then you probably don’t have the MM4 ssp installed in Starter
Instead of usb auto, can you manually put in your profibus settings? Baud etc
Then try to connect with offline project
His screenshot shows V4.5
Should work fine- MM4's have been around awhile
I think its his pg/pc interface setting
Thanks for help i can go online now (y)
as you said PG/PC interface setting , i changed to manual profibus and transmission rate was 12 Mbps ;) i was using 1.5 Mbps :sick:
Hello everyone. Is the PLC CJ1M CPU13 capable of online editing? Or only downloads that will stop the PLC? Thank you.
348
Hi I have a machine that has 1500 cpu program is v15:1 I have the program from the Oem and the tia portal software v15.1 ? I have set the laptop...
1,881
Hello Everyone, I'm a pretty green PLC tech and I need help logging on to some SLC 5/04 PLCs. I have a 1747-UIC and 1747-CP3 cables and I'm using...
6,971
I have issue with going online with Studio 5000. I tried to open the communication path, but I get this message in Who Active I can't do...
17
5,531
Hello All, I’m trying to get online with a local lift station L32E compact Logix processor to pull the program as the local municipality cannot...
26
5,060
