help profibus step 7
israel cerzar
May 2006
mexico
31
hello I have an error in profibus or, one does not follow one another that I have a fault in the network, and when reviewing slave by slave follows the problem equal or reviews and the CPU is one 414, but the program this in way run, or erases slave by slave and the network does not work to me, profibus reviews the port, and apparently this or, single one in a pin I have 4,2 volts, and I continue myself having enla card profibus an external error, tries to run the program èn port mpi and it does not allow step it 7, some solution.
When trying to get a Profibus network going, I have a known working piece of cable and connectors which I plug from the CPU to one station at a time and then build up a working network. This method helps to resolve wiring errors which may be present. Will this help with your problems ?
Hello Israel.
1st.
Write your post so that it is legible !
I could write something allready now, but it would be based on guesswork.
Specify your type of online connection.
Specify your present system. CPU, HMI, Profibus slaves etc. incl. the newtorking layout.
Hello all, I am hopeing someone on here can help me. We currently have our plcs connected to an ethernet network, connected to this is a desktop...
4,298
I need to make communication between a equipment that uses profibus and S5. How can i do it? banghead Anyboody could help me?? thank you all
2,755
Unregistered
U
Hello everyone , im using a IM153 as Decentral Peripherie, it uses profibus and it is a slave with the adress N° 2 everytime there is a problem...
650
After replacing the 70 with the 525, the PLC can read from the drive and recognizes it as online, but no commands are being listened to. PLC is...
595
Ok, We have a couple of hundred PF753's with 20-COMM-P cards installed. I recently had one fail, and it would not communicate over the...
2,146
