help required for vijeo designer
vajeedhbd
Oct 2012
hbd
Hi Guys!
i made a project in vijeo designer v6.1. for XBTGT 5230 hmi.
this project is not being download on usb disk. and there is no error in building process.
when i changed the hmi model to STO531/532, then this download button became active as it can be seen in attached files.
any suggestion plz.
Hey, we got a machine from China (yay hooray -.-) that has some really annoying flaws. Like the HMI screen is going off after a minute which is...
2,196
I have the logic of OMRON but I want to do this logic in TIA 15.1 CPU 1200...
1,849
I have a small application where I need to spec out an actuator. The load is 7kg and needs to move 90 degrees around a 1cm diameter in 1 second...
1,860
I'm currently trying to open an old Medoc/Melsec (Mitsubishi DOS-based PC program) Does anyone know how convert it into windows based program? I...
2,052
i am using PLC of B&R its CPU is CS0104100242. It is showing Error 23 and when i reset this error its cpu shows "INIT" and again it shows error...
1,877
