help S7 300
Mstr
Jun 2010
NY
Hi, this my first time using step7, and this is, i guess, to simple for most of you here, but i don’t have any PLC programming experience.
I need to monitore water flow by setting the pump frequency manually (start the pump (frequency converter), and set it’s frequency from SCADA).
Frequency of the pump is my PLC-s analog input (with permission signal digital input), and flow is my analog output.
My question is:
Is there a FB in S7 300 i can use for this, and does anyone have an example S7 program that can help me, please?
Thank you in advance, Mark.
Are you setting the pump frequency manually or via scada ?
Via SCADA.
I need to run it for few seconds in one frequency, and then i have to change frequency for couple of times, and measure the flow for each frequency.
In SCADA i will have START button and TextBox to set wanted frequency of the pump.
Use the Unscale function.
Setpoint from HMI is 0-100 hz.
That goes into the Unscale function, FC106 I think. I am not at a programming computer. The output of the Unscale function goes to your analog output to the inverter speed reference.
Program the inverter for 0-100 hz, not 0-60 hz. If you need to clamp the inverter use the max speed parameter to limit it to 60 hz. I always leave the inverter at 100 and clamp the setpoint on the few instances I run into when the motor cannot go over X hz. There are as many ways to do this as there are programmers.
In this way 0-x hz setpoint on the SCADA will be 0 - x hz on the inverter.
Thank you for answering, i did unscale for mu frequency output PQW256, and scale for monitoring flow input PIW256. I don't have PLC, i simulated it in PLCsim (i set MD 20 slider:Real, and PIW256 slider:Int- Is this ok?).
Will this work on the real PLC and, if not, what else I have to do to make it work on real PLC?
Q124.0 is my permission signal for frequency converter.
Hello, I have a die punch machine with servo motor for material feeding. I'm using Kinetix 5300 to control the feeding system. Every recipe have...
530
Hi to all, Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic...
1,074
Currently tinkering with a home project for a wood router lift machine using some second hand parts from a redundant timber mill. The servo is a...
2,440
Hi, Expect: we have SIEMENS PLC S7-300: CPU 313C (6ES7313-5BG04-0AB0). we don't have any software to upload its program. we just want to upload...
23
7,883
I have a siemens 317-2 and an old GOT1000 (GT1675M - V) I am trying to get the darn things communication and having no luck. I have followed the...
2,216
