Help Scaling on RSLogix500
marvis
Mar 2016
Italy
108
Good evening to everyone.
I have a question concerning a soldering system on which I am currently working on RsLogix500.
My output current transformer is 5v / 160.
I have 2 analog inputs, current and voltage, both configured in 4-20mA.
My question is about minimum and maximum scaling on SCP command. Is it correct to enter 0-5v and 0-160 or for volt I should find another scaling?
Regarding the scaling, I see from Rockewell manuals that Input Min and Input Max are 6241-31206. Now I find that the value of the current I read at the entrance is 6200, what do I do? Lower the Min input of the scaling?
I hope I have been clear enough.
Thank you.
Hi I have a modicon 984 with proworx 32 that is scaling an analog input, and I need to adjust the scaling. I have new analog input values and %...
1,730
Siemens Tia Portal question. Attached is the norm x and scale x blocks. I'm an AB guy so I'm a little confused. I programmed these networks and...
2,135
Hello, I need to control an Acid pump at a water treatment plant, Using an analogue output of a micrologix 1400. This PLC only has 0-10V analogue...
1,672
Micrlogix 1400 spectrum controls 1762sc-IF8u analog input card Dwyer 628CR-10-GH-P1-E4-S1 0-100 PSI 4-20 Ma We are putting transducers on each...
2,869
Hello all. I am on site trying to scale my rotors controlled with a compact logix through analog inputs and outputs. My brain is racked. The...
1,817
