Help: use FB41 to synchronize two cylinders
allenewong211
Apr 2009
singapore
Hello All,
Good day!
I am currently working on a project in need of using PID control to synchronize two cylinders. I'm writing a PLC program to make sure that these two move with a good alignment. however, as the object they're pushing is with different load distribution, so one is expected to move faster than the other.
THe PLC AO will be connected to proportional valves who, via adjust the orifice size, is able to affect flow rate and hereby the moving speeds of the cylinder rods. Positioning sensors will be connected to PLC AI as feedback. TO simplify the process, we intend to select one as master cylinder and leave the other as slave cylinder who will be controlled to align with the master.
If we denote the displacement of master cylinder as Dm and that of slave as Ds. What are the settings of SP_IN, PV_IN and LMN?
THANK YOU VERY MUCH FOR YOUR TIME AND GUIDANCE IN ADVANCE!
regards
Allen
Hello, Please see attached pictures and tell me why does the output change can you please pin point my mistake i have been searching the net for...
1,941
Hello, I am currently having some problems with regards on using FB41. I can't seem to turn OFF the MAN_ON Data i checked the manual and there it...
1,493
Hi, Im currently using the cpu315-2dp module with an analog input. On the input is a potmeter attached to and I got the assignment from my boss to...
4,203
Hello all, I am an electrical engineering student working on a senior design project with an industry sponsor. We are automating a burst test...
26
13,988
Hi guys, I need help with position control using a Veichi AC Servo Drive model SD600A1-T2-2R2. How do I know how many pulses for it to rotary 1...
