Thyrn
My problem is a have two sensors one high and one low the convylor keeps moving. and i have three plungers only using two high part add a low part need to be sorted having problems with the three loops a wrote keep runing at the same time.
the ladder i have done is this:
start/stop starts convayor
first loop
see if high sensor was hit latch a high bit
if high sensor bit is not latched and low sensors was hit latch low bit
high bit latched start rto timer
low bit latched start rto timer
On the DN bit of both rto start a ton timer for plumger
On the dn bit of the Rto for high bit latch the plunger A
On the dn bit of the rto for the low bit latch the plumger B
On the DN bit of the ton unlatch all and res all rto
this is one loop i need to make it work with three loops so the parts keep sorting with out stoping can i get some help please
first loop
