Help with Lead Lag Standby?
Sep 2022
Earth
Hello all,
I have a triplex pump skid, which they want up to 2 pumps to operate and the other to be on standby. I am kind of racking my brain on figuring out the standby part.
Does anyone have an example of a similar setup that I could look at?
I realize that Rockwell has a P_LLS lead lag standby plantpax module, but the manual is very unclear and from what I can tell it only works with the P_Motor AOI and I am using powerflex 525 drives.
Thank you kindly for any help in advance!
search for [lead lag standby] on this forum, see the [Search the forum using Google] text box above, you might get some ideas from that.
What triggers the standby pump to start? Low Flow? Low Pressure? Running pump failure?
VFD output?
This is a very good question. The LLS block gets a number of pumps that should be running and sticks to that if one fails by starting another one. However, you have to create external logic for the P_LLS to cycle the pumps (there's a command for it) and you'd have to create separate logic to determine whether the number of pumps to be running should be increased.
It works ok for 2 or 3 pumps, but anymore and it's not as nice as it doesn't have a priority or selection scheme to decide which pump to run next (whether to equalize running hours or not).
Hi, Im currently working on programming a Modicon TM221 PLC. I'm using Machine expect Basic/Somachine, I'm having a hard time programming lead...
2,351
I've adjusted the IP of the Panelview Plus as well as the DNS servers; the screen does not show up in the search when I go to the transfer utility...
74
Hi Everyone, I own a GE Versamax controller that I purchased for a class at Long Beach City College a couple of years ago. I lost the use of my...
46
I was wondering if anyone could help i am trying to use a SLC 500 with a 5/05 processor to set up an incremental encoder to a HSCE2 card? The card...
94
Hello, I am working with cimplicity workbench, I have made changes to the current project from this machine I am using in the past. However when...
45
