Help with Mitsubishi fossil required
krk
Aug 2004
Kent
795
Siemens guy here so please be gentle with me......
I am in the unfortunate position where I must monitor an ancient Mitsubishi PLC for diagnostic purposes.
The PLC is a A2-AS CPU-S1
- I have a backup copy of the project file.
- I have a SC-09 cable and have been reliably informed this is OK to connect with.
- What software do I need to buy/acquire to monitor/edit this beast?
You should check with your local Mitsubishi distributor. Most likely you would need GX-Developer (make sure it is not GX-Developer-FX which is scaled down to only support the FX series). It may be possible you may need GX-IEC but I am not familiar with that software
Definitely GX-Developer.
I would recommend preparing to update to a later PLC.
it is not hard to change it to a 'Q' series
(speaking from experience)
Do a search for MEDOC, it is available to down load for free
You will need an older laptop, but this will work with A2 CPU's.
Thanks Paul but I've already stumped up £700+ for GX Developer V8.98 which I'll probably only use just the once....glad it's not my own money.
101
Hi can you help, have a book stitching machine with collates pages in 8 stages. I have installed a camera system that will give an input to...
24
2,027
Is there an output or something that is similar to a screen saver, but you can use in the plc to know when the user is actively using it...
520
I have a Mitsubishi FX2N-64MR-UA1 processor. The 1st analog output card is an FX2N-4DA. It requires 24VDC power. That card is obsolete. The card...
1,608
I have the FX2N-4DA analog output module and I am trying to send a value to one of the channels to give me a 0-10v output. Does anyone have any...
1,435
