Help with Rockwell Automation Ladder Logic for Max Height & Peak Detection
*rodrigp*
Dec 2023
USA
Hi everyone,
I'm working on a project that involves using a Keyence LR-X100 sensor in Studio 5000 V35 ladder logic to determine the object's orientation (right side up or upside down) and verifying the presence of all parts by counting peaks. Our object scan time ranges between 120 - 450ms, with expected max peaks fluctuating from 1 to 5.
We've encountered challenges with color consistency affecting our vision cameras, leading to inaccurate results. I'm conducting tests to explore if sensor-based detection can provide the reliability we seek in achieving these expected outcomes
Any insights, sample logic structures, or advice on utilizing Rockwell Automation software for this purpose would be highly appreciated! Thank you in advance for your assistance.
... challenges with color consistency ...leading to inaccurate results
... Any insights, ...
I recently applied a very robust algorithm developed for the New Horizons trajectory, which is more or less a straight line out of the solar system, to the Lucy trajectory, which orbits the Sun, to find the closest approach of a spacecraft to a planetary body. Guess what? It was not robust for Lucy.
The key to this will be understanding the character (quality, noise, consistency, possible range, timing, short- and long-term degradation, etc.) of the data. Maybe a filter would help, maybe it would not. Solving it in a PLC would not be my first choice, unless the data were very high quality. However, considering the image below I doubt that is the case.
Some folks on this forum will have experience with this kind of thing (french fry lengths come to mind), and may chime in. I doubt many of them solved it entirely in a PLC, which prefers a Pass/Fail input; I thought the selling point for Keyence was providing such a reliable Pass/Fail signal.
If your images are repeatible and show a huge difference between lowest peak and highest valley, then why not count on the transition from peak to valley. Latch when you get above a threshold, then count when it dips below that threshold.
Put some hysteresis in to avoid any noise and you should be counting peaks.
Hi!! I'm looking for Temperature rise calculation software from Rockwell, I just download "Product selection toolbox 2022" but this software is...
219
Hello, I am trying the AOI provided by Rockwell to read Modbus TCP, the version is 2.04 The connection looks good to the modbus server. I...
654
Machine has existing DN devices that are connected to SLC 5/04. All communication is working fine now. Supplier wants to remove some DN devices...
844
Hey I am trying to used the ISATR8800002_2015 from machine builder library, and when I try to use the HMI i get the error cannot interpret area...
699
Good evening, I'm primarily a Siemens user, but I have an incoming project where I need to use Allen Bradley everything. So far I know that the...
2,646
