help with Rslogix 5000 and festo cpx fb32
stu
Aug 2005
England
785
Hi mentors
I have a machine with a contrlogix which it has a festo cpx fb 32 connected to it which works ok , but I was wondering if I could get the fault data into the plc any ideas thanks stu
I'd like it a lot if you put more background information into your posts to indicate what research you've already done. Unless there happens to be a Forum user with recent specific experience, most of the Forum involvement is going to be from users with related experience and interest in the problem.
The Festo 'CPX FB32' is an EtherNet/IP network adapter to which you can add I/O modules and valves.
The product brochure: https://www.festo.com/net/SupportPortal/Files/7486/PSI_210_5_en.pdf
The User Manual: https://www.festo.com/net/en-in_in/SupportPortal/Downloads/149768/166743/541305g1.pdf
The EDS files: https://www.festo.com/net/en-in_in/SupportPortal/Downloads/9273/47617/FB32_EDS_REV21.zip
The User Manual includes some definitions of the System Object and the Status and Diagnostic Object in Appendix B.
You will have to use the MSG instruction to send a CIP Generic message to the module to read any of these objects.
If you can narrow down which object you want to read, we can help you fill out the fields in the MSG instruction to get that data.
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
624
Hello Everyone, I have tried to access the help function from my RSLogix 5000 but everytime I select a function block on the PLC rung and press...
1,291
I’m working with indirect addressing and trying to make an HMI where each Rectangle Object has a tag of “A[0-127]” with a correlating Push Button...
4,229
I have been tasked to upgrade some SquareD PLCs at our plant. I have done several of these upgrades without any issues. However, I have now met my...
2,454
Hi There, When i did FRD instruction in SLC 500 its working, when i try to simulate in RSLogix 5000 same way as i did in SLC 500 which is not...
2,744
