Hi speed DC outputs on ML1400
rrparker07
Jun 2010
Winston, GA
89
Hello all,
Could someone please tell me what I have to do to disable the PWM/PTO function on high speed outputs 2,3,4 of a Micrologix 1400. I am just trying to use them as standard outputs.
Thanks in advance,
Roy
Just don't configure or create a PTO or PWM function involving those outputs, and they'll run just like normal outputs do.
Are the outputs not functioning the way you expect, are you getting an error message in RSLogix 500, or are you just curious about how the configuration works ?
I'm not getting any error messages on the PLC. This application is for a new piece of equipment not yet in production. When we force the output, the display shows the output on and the voltage toggles between 1.4(force off) and 1.8 (force on) DC volts. The programmer/installer wasn't even aware that there were 3 fast and 3 normal outputs in the group so I'm quite sure he just programmed the outputs as normal. That is why I thought you might have to do something to get the normal output function. One thing I did notice was that there was no wire going to the Com terminal for group two which is the one in question. Last week, when the three outs didn't work. He assumed it was the PLC and ordered a replacement. This machine is set for a trial run in the morning so I certainly appreciate the help.
You need to get a wire onto the second com.
On a ML1400 they can be grouped to switch different voltages, or polarity, that means each group uses a separate com.
When you get a new ML1400 there is a manual that show this.
I understand that each group has it's own common. In group two on this 1400, 2,3,4 are the fast outs and 5,6,7 are the regular. In group two there are actually two terminals that are "common" to the group: VDC2 and COM2. I obviously have 24+ going to VDC2 and tried 0VDC and nothing at all on the COM2 terminal. 5,6,7 work fine in either config. But I can't get anything out of 2,3,4.
By the way Ken, I double checked the program this morning and there is no set up for PTO/PWM. There just written like normal outs. ONLY THEY DONT WORK!!!!! AHHHHHHHH
Hi Bernie,
When we couldn't get the starters to pull in, we disconnected the output wires so the voltages read were without the load.
Bernie,
I'm not currently at work so I'll have to do that measurement tomorrow. In the mean time, could you explain to me how and why the fast outputs should have to be wired differently than the regular outputs in that same group (group 2). In the AB documentation, all 6 outs in group two are listed as FET. Are fast outputs and FET two different things?
BTW: the load for all 3 outs in just a small Ormron 24VDC cube relay.
Thanks for the help,
Roy
Thanks for the thought Vaughn, but my problem is I can't get the outputs to show voltage even with the load disconnected.
Re: Fast vs non-Fast FETs, without a detailed schematic it would be a pure guess as to what differentiates them. Though possibly a difference in protection circuitry around the FET may account for speed and characteristics of measured voltages.
Thanks to all whom offered their input.
WHO WOULD'VE BELIEVED that Allen Bradley would make two 1400's with the exact same defect. After the third processor arrived this morning by express courier, we hooked it up and it ran just fine the way it was originally wired.
When the second PLC had the same problem, I assumed it was something on our end. I should have remembered what my Dad said when you ***-u-me something.
Thanks again,
Roy
Hi All!!! It's my first post on this forum so be a patient,please. I'm writing program using RS Logic 5000 and I need have a variable speed...
19
8,536
Hi i am trying to get a Mitsubishi Fxon plc to operate a solenoid valve on and off at high speed, ie it's firing a glue gun on and off, cant seem...
3,130
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
106
Hello, I am trying to setup on plc so If I enter 60 jph (job per hour) it will send the vfd hertz based on what jph is entered by...
166
Sigh, DeviceNet noob... I have a 1756-L55, with a DeviceNet module, and 10 PF700 all commanded with DeviceNet. One of the PF700's blew up...
139
