hidden tags in predefined data-types
broman973
Feb 2013
NJ
19
In RSL5K, I've concluded that the PID_ENHANCED data-type holds errors under hidden tags from previous executions of a PIDE instruction (... PV-Sp errors that is). I'd like to expose those hidden tags, or at least be able to move values to/from them. Is there any way to export them, or make them visible/accessible?
The reason being... I'm trying to "multiplex" 28 controls under a single PID_ENHANCED data-type and single PIDE instruction.
The PIDE and its associated control block are designed, tested, advertised, and supported to be used with a single instance of the control block per instance of the instruction.
While you might have an enjoyable science project going on investigating the inner workings of the Logix OS and its instruction set, from a practical standpoint you should abandon it and use the instruction as it is designed.
The PIDE and its associated control block are designed, tested, advertised...
Not so much "advertised" or I wouldn't be asking. ;-)
That's a nice recommendation, but you're not answering my question. I can successfully multiplex it as long as I set my P & D gains to 0, eliminating the need to accommodate previous PIDE error. Of course, that's unacceptable... hence my question.
Sometimes you have to be impractical to achieve efficiency. As Gene Kranz said from Apollo 13: "I don't care about what anything was DESIGNED to do, I care about what it CAN do."
You are correct that I am not answering your question, but rather arguing against its pursuit.
I have attempted to do similar things, and encountered similar problems, and chose to abandon the process in favor or a more practical and less efficient approach.
Forgive me if I sounded cross or gruff; I don't know you or your application and am probably reading in some history and subtext that is not present.
Good luck with your project !
Hi, I'm an absolute beginner in PLCs.. I have an Allen Bradley SLC5/03 PLC installed on a machine, the program is working well, I uploaded it to...
25
3,868
Hi, I'm a bit new to this and this is my first post, so I hope I'm doing this right. I have an Allen Bradley Family 5 PLC in our plant and I am...
17
4,549
I have a S5-115U, 941B.... In OB1, I can see some block calls Like JU PB16, JU PB17 and so on.... But in the Directory I don't see these blocks at...
44
10,821
Hello, I have a problem with Eplan, and I can't seem to find answer anywhere online. I am working on a project, and I have many pages of...
3,112
Please help me answer this PLC Programming problem. Problem 1. When Start Push Button is pressed, Motor is going to start. When Stop Push...
36
12,361
