High Temp Connectors
firebrd10
Sep 2003
Kentucky
61
I know this isn't a PLC question but I am looking for a Multipin connector (16+) that can withstand a constant 300 degrees F and spikes of 400 degrees F. I am using it for data collection off of a hot mold which is connected to an AB PLC.
Does anyone know of a supplier that offers such a thing????
Getting Desperate
Tim
The objective: Reach about 10’ horizontally into a 1300F furnace, and pick up a 140lb rectangular container, then pull the container back out of...
1,881
A colleague of mine is building panels with physical relay logic and it's fairly labor intensive. Simple applications, maybe 10 relays. I...
4,128
Hello! I am trying to write Modbus TCP to a UDC2500. I keep getting exception code 3(Illegal value) with any register. I am writing from function...
1,816
Good Morning , I have a Oven Band Tracker that I would like to make improvements on. This Oven Band Tracker keeps track of the position of...
2,046
Hi i need to enter some values of temperature for Low-Low, Low, High and High-High temperature sensing. i need to set these values through HMI. if...
1,390
