Hitech HMI to Siemens HMI
rj061991
May 2014
iligan city
75
Hi!
i would like to ask for suggestion what to do in my project..
I have a mitsubishi PLC and a Hitech HMI.. our customer wants to replace the Hitech 1700 STN HMI with Siemens ktp 600 basic color dp... is it possible???.. and what software should i use to do it???
thank you for you answer..
Jorem
The KTP600 DP supports Mitsubishi FX Protocol.
The KTP600 PN supports Mitsubishi MC TCP/IP Protocol.
You need Siemens TIA WinCC Basic to program the KTP600.
Thank You for your reply JesperMP
But how to make the ktpbasiccolor DP communicate to the mitsubishi Fx??.. I have already programmed the Siemens Hmi Using Tia portal.. How to Tag the Hmi Design to the Mitsubishi fx PLC.. it seems they have different addresses and symbols..what software should i use to make it happen??.. thank you
Hi guys, I need the communication cable between S7 300 Siemens PLC and Hitech HMI. Can anyone help me? Many Thanks.
3,796
I want to upload program from model PWS6A00T, but there is a problem it's successfully upload firmware file but when application is started to...
1,230
Hi guys I need help I'm having trouble when uploading the program of Hitech HMI model PWS6A00T. it was successfully uploading the program but...
1,356
How to unlock Hitech HMI upload file *.AA6? I can't reconstruction without this password.
17,533
Hi, I have Hitech PWS 1711 STN HMI.I uploaded a program successfully in PC.It created 2 files .AP1 and .AP2.Now i cant open it.how can i open the...
3,036
