HMI Alarms - Message not showing properly
darkesha
Nov 2007
Calgary
107
Hi, I have FTV site edition (network) and the alarms and Events are setup to be picked up from PLC (checkmark on Enable alarm and event support when right clicked on RSLinx Enterprise/properties/alarms and events).
Problem I have is that message associated with alarms and shown on Alarm and Event Summary page can be:
1. Missing,
2. Wrong,
3. Correct
When cross referenced with (what I think is) source of these messages (under configuration_description tag in particular instruction I see these not matching.
So either source of these is something else, or HMI is not picking up description every time the alarm is tripped.
When I create new alarm, it is shown without description, so either I don't know where this description (message on alarm and event summary page) is coming from and therefore the source string is empty, or if it was supposed to come from add on instruction (the way I believe it is), something is broken in this configuration.
Anyone had this particular problem ?
Found it.
Right click on the alarm_digital and then configure "particular_alarm" or Ctrl+I and there is another set of descriptions and parameters...so beside description in PLC program, the Cnfg_Desc field in the particular add on instruction there is another set of text strings being available....unbelievable.
Hi guys! I want to read a tag name of hmi tag to create a generic alarm message. Do you know if it's possible to do? I'm using factorytalk view...
721
Hi, I'm using tia portal v16 with physical plc 1211c and simulated Hmi TP700 comfort. plc and hmi are connected correctly. I have 2 arrays...
1,589
I have the issue where the HMI alarm summary viewer on the screen is automatically clearing the alarms after 2 days, not all of them just any that...
1,555
hi all, I have the issue where the HMI alarm summary viewer on the screen is automatically clearing the alarms after 2 days, not all of...
1,085
hello everyone can some one tell me IS it possible to Archive the History data backup of Alarms in HMI. HMI model is GS2107-WTBD in case my HMI...
1,120
