HMI as serial server?
Charles1
May 2005
30
Guys,
I have virtual serial port freeware from http://www.hw-group.com/ and I was wondering if I could program and monitor my PLC (Eaton/CH ELC)through my HMI (Eaton/CH Panelmate ePRO PS). I want to be able to have one ethernet connection to the HMI and RS-485 from it to the PLC. What system does this software need to reside? How do I figure out what port numbers correspond to the IP address and the COM port? The ePRO use KEPWare as the OPC server, could this be configured to pass this info from ethernet to serial?
Charles
Guys, I have virtual serial port freeware from http://www.hw-group.com/ and I was wondering if I could program and monitor my PLC (Eaton/CH...
3,156
Hello Friends I have a machine with a barcode reader connected through serial port to a GS2110 HMI and a FX3G CPU. Where can I found the tag...
1,645
Hi All, I am looking to install a Red Lion CR3000 HMI and connect it to a Mitsubishi FX3u 64M PLC via Serial. I cannot find confirmation on...
2,867
I have been asked to figure out why 2 HMI's will not work at the same time that are connected to a GE 90-30 rack with a 352 CPU. The HMI's are...
2,569
I am working to control some objects using Weintek HMI through Fatek PLC. I wrote a simple program to control an output Y_0 using input X_0. I...
3,840
