Hmi bachup
yogesh patil
Dec 2012
pune
We have tp177 hmi siemens. We want to replace with new. We need backup first. I don't have prosave softwear. Can we take backup by wincc flexible softwear.
Keep in mind that an uploaded copy will not be able to be edited? Any chance of getting a hold of the machine builder and getting a copy of the program?
In the panel there may be a "Backup / Restore" function in the control panel that will backup the program to a memory card attached to the panel.
Remember that if you uploading using Prosave, then you can download only to the same HMI. So if your TP177 is not the same as old one you might not be able to load program. Check first if you have the same model. If not then you have to ask siemens support if old and new are compatible.
I have had the copy of a Prosafe file - had to convert it for wincc 2008
it does not convert well - I would download direct to Wincc if you can. then realise that the Security section is totally revamped so you will have problems there.
Ain't that the truth! We needed to add some interlock buttons to a Siemens HMI but the nincompoop that last worked on it brought in a bootleg hub (which is a big time no no in itself) and hooked directly to the HMI in question and modified a bunch of stuff. Then left.
So I was faced with either recreating his buttons (not knowing where they would show up in the PLC didn't help), or forgetting about updating the HMI.
Fortunately, he came back and surprise, surprise, had the current copy on his laptop.
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
57
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
82
147
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
60
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
79
