Hmi beijer with m221
Apr 2015
greece
19
Hello to everyone.I have plc m221 with hmi Beijer and the problemm is that when i put double word(tags) in the hmi i have error message (the adress is invalid).Can someone say how i can put the right variable in the hmi.Thanks
Each driver has a help file that explains the address syntax. In iX Developer, select the Controller -> Settings -> Help.
If you are not able to figure out the correct syntax then we need to know which driver that you are using.
Thanks for the answer i read the help for my controler but it din' say for double word only for intger word and my communication is modbus.What do you mean which driver i use?
who is the master? from which device are you specifying what addresses to read or write to?
Normally from a hmi you have to select a driver and then give an address for the device you are talking to
The master is the plc.The variable i want to read/write is double word (int32) and the problem is how i can write this variable in the hmi the other variable works ok i don't know how i can syntax this the help say only for the intger (int16).The communication is modbus/tcp
hello every body. I want to upload program from E100 HMI Beijer. I have " E - Designer " software and CAB5 programing cable. I tried with USB to...
18
3,255
Hello, Maybe it is just a simple problem, but I cannot solve it. I have a Wago 750-881 connected to a Beier HMI through IP TCP, the connection is...
894
Well, I'm working with this ABB plc project, and It's been a learning experience coming from Allen Bradley. The project can't be changed to an AB...
1,178
Hello, Can somebody tell me how to Upload and Download program from Beijer 1071 Panel Operator/HMI to a CF Card directly without E-Designer, since...
1,458
Hi. I need to get an upload from a Cimrex 30 HMI. According to a label on the back, it's made by Beijer. See attached photos. It's successfully...
2,600
