HMI for home project
andydaoust
Oct 2002
Alaska
56
Hi Everyone,
I'm building a glass kiln. It will be a multi-segment temperature controller. I'm using an SLC 500 5/04. I'll probably buy a 5/05 for ethernet. I don't need the Panelview software and hardware to interface with the PLC. I can use RS Logix. I would however, like to set up the home computor so my wife could enter a temperature profile and monitor the kiln from inside the house. I thought there might be an inexpensive HMI as compared to the Panel View setup. I searched for HMI; there were many hits. Maybe you could help me narrow my focus.
Thanks,
Andy
Check out www.kepsales.com...
http://www.kepsales.com/hmi-products.htm
If the SLC 5/05 is in your price range Infilink should be, too. You can use RSLinx as your OPC server, or the KEPWare server (supports AB Ethernet). You can even download free time-limited trials if you want to check it out.
Be aware: when you call for pricing, you might get me on the phone. Take that for what it's worth. I don't want to use this message board inappropriately.
AK
I've never done it but I've read that the 5/05 (latest OS models only) can contain a small web page which should allow you to enter and monitor values.
Some info is at:
http://www.ab.com/manuals/cp/1747-rn009a-en-p.pdf
SLC 5/05 processors with OS501, Series C, FRN 6 (or higher) include
not only the enhanced embedded web server (introduced in FRNC/5)
which allows viewing of not only module information, TCP/IP
configuration, and diagnostic information, but also the data table
memory map, data table monitor screen, and user-provided web
pages via Ethernet using a standard web browser.
Someone here might have a link with more info or experience.
nOrM
I like the idea of using Excel. Any hints on how to get started? How would the data get between the PC and PLC? I must have to set up some sort of server eh? I know how to write the basic PLC program. In fact I'm mostly done with the ladder. I don't know much about Excel as a datbase. I'll be going to Tasmania to ride my bicycle in March.
Thanks,
Andy
If your going to use excel you'll need an I/O server RSLInx will do fine as long as its not the lite version then for monitoring you'll just need to set up DDE links..
i.e
1. Setup a topic in RSlinxs DDE/OPC (menu)>> Topic configuration
2. Creat a topic linked to the revevent PLC
3. Then to get data into excel use a =RSlinx|Topicname!'Bit address'
e.g =RSlinx|Kiln!'B3/0' would return the state of bit B3/0 1 or 0
=RSlinx|Kiln!'N7/0' would return the value in N7:0
Hope that helps any problems leave a message I have a few examples I could mail you if required...
Jezz
^^^Yeah, what he said ;)
However, it sounds like you'd also need to poke data to the PLC from Excel. In the Rockwell knowledgebase do a search with RSLinx selected in the product family field and Excel entered as a keyword. There are tons of results, many giving VBA examples and sample excel spreadsheets of how to do this using OPC, DDE, asynch writes, tables, etc...
Sorry I have not replied sooner. I had to work. Thanks for the information. I have RSlinx lite. The information has helped me learn a lot more about PLC's however. The link to the knowledge base was very helpful.
Thanks again,
Andy
Hi, I'm looking for a HMI or just a display if I can't find a HMI. I will soon have a s7-1200 at home providing some information and control. I...
1,494
Has anyone ever used a HMI to automate their own or someone's residence? If so in what capacity? Why would you or wouldn't you recommend this?
18
7,498
What is the best way to show a modules LED status lights on an HMI screen? The module I'm trying to mimic is the 1756-DNB DeviceNet Scanner...
20
I'm having a hard time either remembering or figuring this out. I have a PLC program and the associated HMI program. I know what this means...
117
Hello, I'm working with Studio 5000 and ME Station, and I'm trying to find a way to detect if the PC with the HMI is shut down or not. I've tried...
154
