HMI mounting clips
JohnKhoury28
Mar 2014
Currently in Lomita, CA
24
Can some please direct me to find the mounting clips for 2711C-T4T HMI Display (Panelview c400)? Is there a P/N? I looked all over the datasheets for the correct ones and there is no indication of what the P/N is. The HMI I ordered did not have the mounting clips with the display. Thank you for your time.
PanelView Mounting Levers or Clips
Ian,
Just for your information, the link you posted won't work because the RA/AB Product Catalog...
https://raise.rockwellautomation.com/raconfig/browsecatalog.asp
...is session based, so it will timeout any results pages you load. You are indeed correct on the order number you provided.
More info...
There are two types of mounting accessories for the PanelView terminals...
Plastic Mounting Levers for PanelView Plus 400/600 terminals, PanelView Plus 6 terminals, and PanelView Component terminals:
Part number: 77162-009-01
Order number: 2711P-RTFC
Quantity: 8
2711P-RTFC Installation Instructions: Publication 2711P-IN016A-MU-P - August 2003
Metal Mounting Clips for PanelView Plus 700-1500 terminals, PanelView Plus 6 terminals, and PanelView Plus CE terminals:
Part number: 77158-008-1
Order number: 2711P-RTMC
Quantity: 8
2711P-RTMC Installation Instructions: Publication 2711P-IN006B-MU-P - March 2007
Regards,
George
p.s. attached is a photo of the kit you need which I grabbed from the stores...
So the question was raised to me today about an 6” HMI installed in a small jic enclosure that is mounted on piece of 3/4” rigid conduit bent to a...
1,060
Hi all, I have a TP2200 which I would like to mount on a rotating arm of some sort. The only ones Siemens supply go up to TP1500 max. Has...
1,116
What are the opinions and standard you use for placement of HMI screens? Most of them in this plant are mounted vertical (no slope) at about...
17,243
hi there, I'm a beginner pls help when transferring pc to hmi there's an error message on shihlin hmi written com1 station 1: communication...
70
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
149
