HMI touch operator panels
Shohadawy
Aug 2008
Egypt
66
I'm a newbie to HMI operator panels programming. I'm asking about the addressing of the objects that you insert in the HMI operator panel designing software, What is the principle of addressing.... Shall it have the same addresses that I assign for my PLC operands?
Most objects will have a local HMI address (name) and the ones that interact with the PLC will have a PLC (link address=tags). You need to be specific! A lot of people will have an HMI file in the PLC program that has the same names as the HMI tags. EXAMPLE: Start in the HMI will interact with the bit Start in the PLC.
The names and addresses are the same. In the PLC software, Export documentation. It will save it as a CSV file. Launch the HMI software, and Import the file.
You could do the reverse from the HMI software. Export from HMI, Import in PLC. One of the software packages is your Master for creating tag names (Export) and the other is the Slave (Import). I usually use the PLC software as my Master.
While writing and editing, more tag names are added. Do another Export to keep the CSV file updated. Every time you jump over to the HMI, do another Import.
At the end, your HMI Tag Database will have a bunch of tags that are unused. The HMI software is smart enough to know which tags are usd, and which ones are unused. You can Select and Delete unused tags. You need to do this so the HMI won't waste time updating unused tags.
hi all i am new here i have a mitsubishi smart touch hmi i.e ms-60t-pe but i cannot find a software to edit and download a program in it any help...
169
I HAVE SMART TOUCH MS-60T-Pe MITSUBISHI HMI BUT I CANT FIND A SOFTWARE TO EDITE AND DOWNLOAD A PROGRAM IN IT.......CAN ANYONE HELP PLEASE!
78
hi everyone. i hope you guys are doing great. i am trying to built communication between aveva intouch hmi 2023 and tia portal v18. i dont have...
583
Good day, May I ask, what do I need to perform MIGRATION of HMI program from Siemens MP277 10" Touch hmi to TP1200. I already have WinCC Flexible...
170
Has anyone ever replaced a touch screen on a legacy Red Lion G3 series HMI?
1,467
