HMI transparent communication problem
bertrum
Apr 2006
Portsmouth
Hello
I have mitsubishi e1101 hmi connected to an A1S CPU, the hmi is also connected to the internet via the ethernet port. I have set up remote access to the hmi successfully but I am stuck setting up transparent port communicatios to the PLC over the internet via the HMI. In the e-designer software it says the transparent port can function through the ethernet port, and I have followed the instructions but I am still stuck. I cannot transfer e-designer projects using tcp/ip transfer either.
I have tried using a virtual serial port program to convert the serial communications into A TCP/IP signal to the HMI ethernet port. This is to fool the PLC program software (GX developer) into thinking it is communicating to the PLC using serial communication, but again this has nt been successful.
Any help would be much appreciated.
Kind Regards
Bertrum
I have not found out a way to do the transparent mode on my customer's E1100 and A1S yet, but just a few cents here. what is the connection type between your E1101 and the A1S? Did you enable the transparent mode in your A1S program.
cheers
feng
Hi, I am trying to layout my HMI with various graphics I have drawn up outside of the HMI - I want to have a custom background as well but when...
7,135
I have a cell with a compact guardlogix as the plc and I have three hmi's and two vfd's on this cell. I been experiencing momentary comms faults...
107
What is the best way to show a modules LED status lights on an HMI screen? The module I'm trying to mimic is the 1756-DNB DeviceNet Scanner...
50
I'm having a hard time either remembering or figuring this out. I have a PLC program and the associated HMI program. I know what this means...
118
Hello, I'm working with Studio 5000 and ME Station, and I'm trying to find a way to detect if the PC with the HMI is shut down or not. I've tried...
191
