HMI Trend View
franchois13
Nov 2008
london
76
Hi Guys, need some advice how can I monitor a switch ON OFF states and show it on a trend view like a square wave.
I have been trying it but something is wrong and tag is always not valid.
I am not sure if it is actually possible.
I am using siemens 4" basic panel and portal v13.
I have not checked out above links, but in short, you can use your bit to move an integer to a tag and trend that tag.
... how can I monitor a switch ON OFF states and show it on a trend view like a square wave.
a) In the tag you're plotting, look for a property named logging mode or something similar. Try changing that property to "on transition" or "on change".
b) Choose a short range (y axis) since your signal will be changing from 0 to 1.
Appreciate all the suggestion guys, all contributed to my learning this new thing.
I got it working indirectly as you described above.
But I have noticed it only runs a few minutes and the trend will be reset and start over again. Is there a way to make it run longer so I can go backwards after a few hours and still be able to see the graph?
If you log the tag, then you can set the trend to display the log instead of the live data. However, especially on a 4" screen, it might be hard to navigate back in time.
Tried and worked on mp277 10" but as you said I am struggling on the basic panel maybe it has a limited functionality.
Appreciated all your ideas. Thanks.
I'm attaching an image. Ideally, I want to display a week worth of data on the hmi, but the max seconds I can enter for the x axis second display...
808
Is there anybody know why Histrend do not display the trend (i had sticked LOG DATA )? The current value of sensor is still display, if you've got...
1,101
Good afternoon guys. Thanks to all for the really good info I have gotten on the site thus far. Could not believe how many ways there are to do...
4,553
Hi Is it possible with Siemens panels KTP (KTP 600 for example) to create a graph in wich I can see the values of a variable in function of...
2,651
hi there, I'm a beginner pls help when transferring pc to hmi there's an error message on shihlin hmi written com1 station 1: communication...
83
