toddster900
Hi All
I have a Honeywell Experion DCS system with several C200 racks. I am trying to take an average over a set time of several instrument readings.
I have tried using the ROLLAVG block but I cant add it to any assigned CMs. I can add it to an unassigned CM but when I then try to assign that CM I get the following error.
"Cannot assign to CPU because ROLLAVG is not compatible with the execution environment."
If this is the case and the ROLLAVG block is not compatible with C200s is there another block I can use? I have looked but cant see any.
As always any help would be much appreciated!
