Honeywell experion HS
joaco1993
Sep 2014
newyork
237
Hi, im trying to create a simple popup which is called by a pushbutton in my main display. This is OK and got it working.
Now i want to have a pushbutton in the popup that says CLOSE in order to close the popup..
I saw in the help files, that this should be done by simply writting in the script of the pusbutton: window.explore.close
The script of the PB looks like this:
Sub pushbutton001_onclick
End Sub
However it doesnt work, and gives an error : Object doesnt support this property or methos 'window.external.close'
Hello all, calling anyone with some experience in both AB and EPKS... We have an Experion PKS DCS system that is running on all C200 hardware...
671
We have a Powerflex 753 drive on a 192.168.1.X network that I can communicate with a Controllogix L71 with no issues on same network...
1,443
I have a requirement to get SOE data from Triconex's Trident controller to Honeywell's Experion system. Trident has CIM module (Model 3211), with...
1,537
Hi All I am using a number of C200 racks with several assets configured to help filter alarms. I now want to filter the alarms dependant on the...
2,468
Hi All I am currently trying to control a weigher over Profibus from an Experion DCS. I know there is byte swapping as I have successfully...
2,322
