Honeywell HC900 & Experion Vista: Alarm Group capabilities
plc.learner
Sep 2009
Pennsylvania
Hello everyone,
A quick question regarding a Honeywell HC900 Hybrid controller and Honeywell Experion Vista HMI:
I would like to know if Experion Vista HMI has the capability of reading any of the tags that are selected internally in an alarm group function block on the PLC side. If that is possible, would this method save the extra individual alarm tags in Quick Builder?
Thanks!
It has been a while since I have worked with Experion but the HC900 does not expose the Alarm List in the Alarm Blocks via Modbus. If you are using the Universal Modbus Driver or a straight Modbus/TCP driver you'll have to build the alarms yourself in Quickbuilder.
I don't think there is a ELN Driver, but even if there is, I don't think that driver would have access to the Alarm List, either.
Hey Guys, I am getting random rack/slot errors. I go to download and everything is ok but then it has a error. For example - Yesterday everything...
375
Hello Guys, I'm working on Honeywell HC900. I am using the PID block. I have attached the Switch and loop block to it as well. I have attached a...
647
Does anyone have experience with setting up a HC900 to a prosoft card? Using this to communicate with an Allen Bradley plc
710
Greetings! I'm trying to connect HC900 to Kepserver in Plant via HC900 ethernet driver provided by Kepserver. I put the IP address and most of...
1,129
Hello All, I have problem with Honeywell HC900 C50 CPU, the problem is my all local IOs cards not communicate with CPU. I attached a picture of...
1,667
