Honeywell IPC 620-15
asia548
Jun 2006
Medan
I got two honeywell plc, IPC 620-15, the processor module is 620-1537. One is working, the other has lost its program. I need to copy the program from the working one to the second one. I do not have both the software and the cable to do this. Could anyone please help me out? I need pin out diagram and software to download from pc to plc. thank you in advance
Honeywell just recently introduced a Windows based loader for the 620 series. Former versions were DOS based.
Your local Honeywell rep can help you with pricing for the loader software. Part numbers are in the note below.
Here's the Honeywell announcement:
Honeywell is pleased to announce the release for sale of the 620 WinLoader, version 5.4
The 620 WinLoader replaces the 620 MS-DOS Loader. The 620 MS-DOS Loader was an MS-DOS based software that would not function in current Windows operating systems. The 620 WinLoader addresses this issue in that it is fully compatible with Windows 2000 & XP operating systems.
Additional changes are listed below:
- The Terminal Emulator & Utility Functions are not supported in the 620 WinLoader. - Serial printer implementation must be done using the MODE command (described in the user documentation).
- The Append Ladder Logic function will validate the file to be appended and will be appended only if the file does not contain any invalid op codes.
- This release includes a self extractor that will also install the RTDM and UAIM configuration utilities. The RTDM & UAIM utilities are no longer purchased as separate software Known Issues in this release:
- This was not tested on multidrop configuration.
- Inserting an Indirect Sendout instruction without defining a valid register value clears program memory. This is a platform issue and was not addressed in this release.
Ordering: The 620 WinLoader has the following new part numbers.
623-6225 620 WinLoader (complete with converter & cables)
623-6226 620 WinLoader (software & documentation only)
Dan
Do you have a phone number for Honeywell tech support on USA
Hi there,
Is there a tech support for Honeywell 620 series PLC with MiniCOP in USA? Do you have a phone number?
I appreciate your help.
Best regards,
George
Hi there,
Best regards,
George
Honeywell TAC (technical assistance center) 1-800-423-9883
Hi, I have problem with Honeywell IPC 620-15 PLC. It just stopped working and I can get it into RUN mode again, although keyswitch is in RUN mode...
1,766
Does anyone know of a suitable OPC server for a honeywell IPC 620-35 which I can use to communicate with a scada package? Any help -greatly...
4,404
Hi all, I need to convert IPC 620 Honeywell PLC Program to Control Logix. I don't have IPC 620 PLC programming manual to refer for some...
7,606
Hi, I have some questions on Honeywell CIM (communication Interface module, model 621-0043). We are using PCDM (PC Data Manager) to monitor our...
4,919
Hi I would like to know how to connect to plc honeywell ipc623-60 for make ladder diagram please advise me for hardware (how to make or to find...
6,469
