How can i get Siemens SCADA license
HamzaAhmed
Aug 2020
Palestine
86
Hi guys,
I am going to use Siemens SCADA but i have to buy their license.
How can i know what type of license i need?
It their license depends on the number on tags? or annually commission or what?
Which scada software?
V7.x or WinCC Professional?
But yes, both are based on tag count and whether you are developing or just run time
I don't know what software i need.
I need to make SCADA connected with PLC micrologix 1400 via modbus.
is that possible? what do you suggest?
Is all your hardware rockwell? Why did you pick siemens for scada?
If it's all the same to you go with Ignition.
Siemens has different levels of WinCC in TIA portal, the which to choose is dependent on the application the visualization is done for.
I don't know the different between Tia portal or V7, who is the best for SCADA?
500tag
V7 is a full blown SCADA... it's not just a license, but a whole lot of things to account for like Operating System, etc...
500 tags also seem very low for a SCADA system (assuming it's all brand new), so do you mean SCADA or HMI?
Hello Guys, Newbie with Siemens here. I will be configuring and deploying for a project of mine for WinCC redundancy. I have read this article...
7,323
I have somatic WinCC Run-time Advanced license v16. What software will I require to develop the SCADA project ? I have TIA Portal installed on...
2,106
Gents - hope somebody can help out, I've been tasked with fixing an OLD SCADA system. I've got an S7-226 PLC thats configured for Modbus comms via...
1,456
Hi all, Got a client who has requested a SCADA system for downtime tracking and so on. Right now, they want to implement it as a standalone...
20
7,840
Hello all, Does anybody have tested to communicate SCADA Fix with Siemens S7 via nettoplcsim? Cheers Raffe
1,546
