You can't enable forces until you first have forces present. In the SLC, you select a point to force from the data table or from the ladder window and apply the force. Then the indicator for forces should change from "no forces" to "forces present". At that point, you should be able to click the drop down arrow and select "enable forces". In some Micrologix, forces are always enabled, so this 2nd step is not necessary nor available.
