DamianInRochester
I don't really agree with this statement. I would say it is a lot easier to program S7 that way, but not in general across all formats.Giving the chance to start with Siemens: for me it is easy to use compared to A-B (which until now I am learning).
I admit that using STL programming is a lot easier compared to using LAD and FBD. Because in STL programming, you just type the program as long as you know and understand the logic,
In RSLogix5000 as well as many others, You can just type programs in ladder in relatively the same fashion that you do in STL. It is just a matter of learning the mneumonics, which is the same thing you have to do to learn STL anyhow.
When I am doing code for example in RSLogix, even in ladder I rarely reach for the mouse.
And "just typing it in" doesn't necessarily mean your getting more work done per unit of time, because typing the same logic structure may simply require more effort to type. It all depends.
Not true, you can perform conditional jumps in ladder just as well in most other PLC software, including Control Logix.plus there are some commands that only STL programming can do (such as JCN)
, while in FBD or LAD, if you're not aware of the "short-cut keys" you need to drag-drop every item.
Again, you can enter ladder in through the keyboard. You just need to remember the instructions. Which is the same thing you have to do in STL. So the only difference I see is with STL you are limited to only doing it one way.
While in A-B, components still needs to be configured in RSLinx (needs to have license), a different license for RSView32, RSLogix and other A-B software. Although I found A-B a bit easier to program (drag-drop). But what I don't like with it is the different licenses that you need to purchase and install for different software. Plus the technical support of A-B is not that much felt here *peace*.
We definitely agree on this. I can go on and on about the many things that tick me off about AB. But around here they rule the roost.
