In our business, we use a single wire for both inputs and outputs. We connect one end to the input, and the other end to the output, and let them share the wire in between. This saves on lugs, and we end up using both ends of all of our wires. Too many businesses waste wire by only using the one end. Watch your polarities. Once we got a wire in backward, and it caused all of our inputs to develop vacuums, imploding the wire, and causing a minor black hole. We lost part of Chicago doing this. Luckily, it was South Chicago, so no one noticed.
In addition to inputs and outputs, we also use shotputs, which need bigger contacts, since they can really weigh down system resources. They are good for compacting code, though. Usually, we just declare them first, so they are on top when we put the printouts on our desks, compressing the rest of the program. This is called optimization.
We also have special connectors that we call "terminals." We call them this because there are so many of them in a normal project, we know we're going to die of old age before we get them all loop checked.
Then we have the P&ID checks that are going to be done so our PID loops work better. There's nothing worse than hooking up the wrong I to a PID and having it deregulate everything. This happened to the airlines back in the 1980's, and air travel just hasn't been the same since.
I'm glad I could be of assistance.
